I have put in 2 different resistors and blower motor. Still no other speeds. At the electrical pigtail that plugs into the resistor those terminals for each speed only have 6.5v. When blower motor is plugged in and you try different speeds the fresh/recirculating button A/C rear def buttons will either not light or half light and won’t turn off until you turn the key off to reset. If motor is not plugged in then no issues turning speed dial or other buttons on HVAC control module.
Any idea’s?
Any idea’s?
Nov 26, 2019 at 11:32 AM
