Sorry that I overlooked that. It's top secret and I can't tell you! Actually, I don't know exactly where it is, but the heat sink on it has to be air-cooled by the air getting blown through the heater box. You're going to find this assembly on the top or side of the heater box under the right side of the dash. It is bolted on where you can get to it to replace it, but on some cars that is done by removing the glove box.
If you have a computer-controlled system, you typically won't have a resistor assembly. With a resistor assembly, you're going to have three or four fan speed choices. If you can vary the fan speed anywhere between low and high by turning a dial or pressing "up" and "down" buttons, that has a computer involved that uses pulse-width modulation. No resistor is used with that system. This is what I was referring to where you get the convenience of the variable speed fan at the cost of a huge repair bill.
Oct 5, 2020 at 11:38 AM
(Merged)
