SUV listed above two door with a 4l60e transmission.
Two years ago put on all new A/C under the hood and new climate control module in the dash. with in a year the high fan control setting stopped working. I waited until now to resolve it as I was going to change the engine.
So I replaced the dash environment control module switch. I replaced the A/C box resistor. Tried the unit still not running on high.
I then replaced the Fuse box relay and the relay that sits beside the resister under the dash. Still does not run on high switch setting.
I spoke to several mechanics they said there is a fuse in the fuse box under the hood that powers the high setting. Turns out inside the lid there is a listing for a fuse but this SUV simply does not have that fuse equipped in there. Not sure if they changed the set up from 1998 and a half through 1999 and a half but that is what i am looking at. The vehicle is stock.
May 11, 2019 at 11:25 AM
