Air conditioner blower motor will not turn on
2008 KIA AMANTI
122,000 MILES • 2.0L • V6 • FWD • AUTOMATIC
LARRY'S
  • 6 POSTS
The AC/heater blower motor will not come on. There are no blown fuses in either fuse block, that I can see. I cannot find the blower relay.
Nov 29, 2016 at 10:30 AM
HMAC300
  • 48,601 POSTS
see picture for location. it is in dash fuse box.
Nov 29, 2016 at 12:14 PM
LARRY'S
  • 6 POSTS
There is only fuses in in the dash fuse box.
Nov 29, 2016 at 12:38 PM
LARRY'S
  • 6 POSTS
It is located in the engine compartment.
Nov 29, 2016 at 12:47 PM
Hey Larry,
Here is a guide that can help you test the blower motor and circuit.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Did you find the relay?
Please let us know happens so it will help others.
Best, Ken
Dec 1, 2016 at 12:16 PM
LARRY'S
  • 6 POSTS
Thanks Ken,
I found the relay, replaced it but it didn't help. If it hadn't have rained all day today I would have removed the blower motor. I will let you know if that fixes the problem. Hate let my wife drive it without being able to use the defrost function.
Dec 3, 2016 at 9:21 PM
HMAC300
  • 48,601 POSTS
check to see if there is power coming to the blower first before replacing it . if this is auto temp control where you set temp then it HAS to be scanned by a mechanic to see what is wrong with the unit.
Dec 4, 2016 at 7:57 AM
Hey Larry,
Here is a complete wiring diagram for the car, check for power at the relay first then go from there. It looks like there is a fusible link 30 amp, check there first.
Please let us know what you find so it will help others.
Best, Ken
Dec 4, 2016 at 12:01 PM
LARRY'S
  • 6 POSTS
Thanks Ken, the blower motor runs when wired directly to the battery, and I have 9.4 volts at the connector, but still won't run using the control panel. So I guess it's back to Kia to have them check it out.
Dec 11, 2016 at 10:23 AM
Hey Larry,
Did you check the system ground? Also the blower reply?
Best, Ken
Dec 12, 2016 at 9:39 AM
LARRY'S
  • 6 POSTS
I replaced the blower relay, just incase it was bad or weak. Other than the battery ground I haven't.
Thanks, Larry
Dec 12, 2016 at 10:47 AM
