I have checked every relay and fuse and resistor. Nothing seems to be the problem. I even checked the voltage on the connectors to the blower motor and resistor both are good. I have the blower motor hardwired to my battery now. And it works. The resistor was not giving out any ohms when tested for resistance but i got another one and it is now. even bought a new blower motor sent that back though since that was not the problem.
things i checked:
-Accessory delay relay 1.
-Accessory delay relay 2.
-Auxiliary blower motor relay (28) under hood.
-Front Climate Control System Blower Motor (14)under hood.
-Relay on driver side kick panel.
My question is what else is there to check? All i did was bypass all the relays and resistor and it works. Also, what readings should i be getting on the relays? I have the digital dual climate control unit.
things i checked:
Jun 29, 2017 at 1:31 PM
