Hello! I have had weak and inconsistent output from my vehicle's HVAC system for some time. Then, last month, the blower motor would intermittently fail to turn on. I replaced the motor and now I am getting consistent but very, very low output from the vents.
When I was replaced the blower motor I discovered that one of the electrical connector leads had melted a bit on the male wiring end. I replaced it with a crimp-on replacement part.
Does this seem like a possible blower motor resistor issue? I guess it could also be a physical blockage, but seems more likely that it is a resistor issue. Or I may have screwed up the replacement wiring connector.
Should I put the multi-meter on the connector and see if it is low? What range is normal? I am a total weekend warrior here, so I do not know much about what I am doing other than from watching videos. Any suggestions or insights would be much appreciated.
Cheers,
Matt
Cheers,
Matt
Oct 17, 2018 at 9:25 AM
