Blower motor blowing fuses. Replaced motor, still doing same. Runs on all speeds for approximately five to ten seconds then fuse blows.
Dec 30, 2018 at 4:33 PM
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny.
It sounds like you are having a problem with the blower motor resistor. Check to see if the harness/connector is melted/burnt/loose/damaged. Here is a tutorial showing blower motor replacement if it helps:
I've attached a few pictures below of its location.It's under right side of dash next to blower motor.Hope this helps and thanks for using 2CarPros.
Danny-
Dec 30, 2018 at 5:55 PM
BMDOUBLE
CERTIFIED EXPERT
I second the resistor idea. Also a good inspection of all the wiring would be a good idea! These cars had the wire harness recall due to crumbling insulation back in the day.
