The blower motor does not work but my compressor clicks on?
2004 CHEVROLET MONTE CARLO
148,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BENARD MILLER
I replaced the blower motor, resistor, ignition and control module. All fuses and relay are good. No power to my resistor.
Sep 5, 2022 at 8:10 PM
We need to check for power using a test light for the fuse (HVAC Blower 30 amp), in the under-hood fuse panel, this guide can help and the fuse location in the diagrams below, also I have included HVAC wiring diagrams so you can see how the system works.
Sep 6, 2022 at 10:05 AM
BENARD MILLER
I already used the test light every fuse and relay lit up fine using the test light.
Sep 6, 2022 at 11:57 AM
Okay, can you test for power at the red wire at the resistor? If you look at the wiring diagrams you can see that it is a straight shot from the fuse to the blower motor resistor.
Sep 7, 2022 at 12:10 PM
BENARD MILLER
I already tested the red wire entering the resistor and there's no power. The HVAC blower 30 amp is good I checked it with a test light and that's what's puzzling me.
Sep 8, 2022 at 8:07 AM
You can see from the wiring diagrams it is a straight shot from the fuse to the power of the resistor, I would run a new power wire to the resistor. Let me know.
Sep 9, 2022 at 5:28 PM
