If it worked when you tapped it, chances are the motor itself is bad. If you look at the first four attached pictures below, they are a diagnostic flow chart to confirm the motor is bad. Keep in mind, a damaged or corroded connection or wire can cause this type of problem too.
If you decide the motor is the problem, here is a link that shows how one is replaced in general.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Here are the directions specific to your vehicle for replacement. See the indicated pictures which correlate with these directions.
BLOWER UNIT REPLACEMENT
See Picture 5
1. Remove the glove box lower panel and disconnect the connector from it.
See Picture 6
2. Disconnect the glove box light connector and glove box mounting bolts, then remove the glove box.
See Picture 7
See Picture 8
3. Remove the right glove box side cover, the dashboard side cover and the left glove box side cover.
See Picture 9
4. Remove the glove box frame mounting bolts, then remove the glove box frame.
See Picture 10
5. Disconnect the connectors as shown.
6. Remove the blower unit mounting bolts and screws, then remove the blower unit.
7. Install the blower unit in the reverse order of removal, then make sure it runs and doesn't leak any air.
____________________________
If you decide to follow the diagnostic flow charts (pictures 1 - 4), here are a few links that may be helpful:
https://www.2carpros.com/articles/how-a-car-fuse-works
Feb 1, 2019 at 2:25 PM
