Blower/heater
2004 HONDA ODYSSEY
150,000 MILES • V6 • AUTOMATIC
BDUFFY
The front heat is warm (what is coming out) but the blower does not blow. I have already replaced the blower motor and the resistor. Any other suggestions?
Dec 29, 2017 at 6:21 AM
KHLOW2008
  • 41,814 POSTS
Hi bDUFFY,
You need to check the voltage power supply to the blower motor. It could be a bad fuse, power control relay or wiring fault.
Dec 31, 2017 at 12:35 AM
BDUFFY
Thank you for responding!Fuse is good, as is relay. How do I access the wiring?
Dec 31, 2017 at 8:57 AM
good morning
did you verify power to the relay from both fuses?? the circuiy is a ground control. with the switch on, you should have power on both sides of the blower motor and you should have power at the blower resistor. the circuit is then grounded by the blower switch in the dash.
Jan 2, 2018 at 3:00 AM
