They will work several times in a row, then not work several times in a row. When they work, the lights on the AC on/off switch and the inside/outside air selector are on. When they do not work, those lights are unlit, indicating no power going to/through those switches. When parked in the garage, and the engine is started, if the headlights (daytime running lights) come on, the fan/AC works. When the headlights do not come on, it seems the fan/AC does not. I replaced the AC relay in the engine compartment fuse block, but upon testing, it was okay. So, does this problem go back to the ignition switch, or a contact or relay associated with the ignition switch?
Dan Roder, Fairhope Alabama
Oct 4, 2018 at 12:04 PM
