Blinkers not working. No light on, nothing. Replace turn signal and relay. Any ideas? Bernie
Aug 25, 2018 at 5:12 PM
WHSW2002
MEMBER
I would check the fuse to make sure it had not blown.
Aug 25, 2018 at 5:24 PM
BERNIE WINE
MEMBER
They are all good checked with test light. I am at a loss on what to do. Never had this problem before, like no power to turn of flashers.
Aug 25, 2018 at 5:33 PM
WHSW2002
MEMBER
I would check the fuse to make sure it had not blown. Then I would replace the flasher.
Aug 25, 2018 at 5:40 PM
BERNIE WINE
MEMBER
Okay thanks. Replaced relay with is behind radio. Where is flasher? Probably next to relay?
Aug 25, 2018 at 5:43 PM
WHSW2002
MEMBER
You will need to check a repair manual (physical copy or online) to find the location of the flasher in your vehicle. Mine is under the dashboard on the driver side.
Aug 25, 2018 at 6:06 PM
BERNIE WINE
MEMBER
I will thank you for the help. Blessings, Bernie
Aug 25, 2018 at 6:16 PM
CERTIFIED EXPERT
Here is the location of the flasher module and the blinker wiring diagrams to help you see how the system works. Here is a guide to help you check to see if you are losing power somewhere:
Aug 25, 2018 at 7:38 PM
WHSW2002
MEMBER
Nice diagrams!
Aug 26, 2018 at 5:07 PM
BERNIE WINE
MEMBER
I pulled the cover down under dash where I think they say flasher is. but it is not there. My power steering pump and some wires.
Aug 26, 2018 at 5:36 PM
CERTIFIED EXPERT
It should be there but it up high under the dash (hidden) use a flashlight to help.
Aug 27, 2018 at 10:27 AM
BERNIE WINE
MEMBER
Okay, will look again, thanks. My body does not bend so well these days, lol. Thanks again.
Aug 27, 2018 at 11:04 AM
CERTIFIED EXPERT
Mine neither, lol .
Aug 28, 2018 at 9:52 AM
BERNIE WINE
MEMBER
Hey ken, was taking car for ride and car not shifting onto high and most of lights go on on dash. Could this be a BCM or computer problem? What do you think?
Aug 28, 2018 at 9:57 AM
CERTIFIED EXPERT
These problems sounds separate can you please start a new question of the shifting issues?
Please post your new question here, you must be logged in.
Today it started with not shifting into high gear. Also all dash lights came on and with turn signals not work in thinking it is a computer problem maybe BCM or ECM not sure.
Aug 28, 2018 at 10:51 AM
CERTIFIED EXPERT
Hmm, maybe it is related. It can be the BCM causing the is issue. Lets remove the BCM electrical connectors to check for corrosion. Sometimes just removing and replacing the connector helps solve the problem. Here is the location.
Image (Click to enlarge)
Aug 29, 2018 at 9:59 AM
BERNIE WINE
MEMBER
Will try tomorrow after this heat wave we are having in Long Island. Thanks again Ken. Blessings, Bernie
Aug 29, 2018 at 11:17 AM
CERTIFIED EXPERT
Sounds good looking forward to seeing what happens. Hope it cools for you.
Aug 30, 2018 at 9:43 AM
BERNIE WINE
MEMBER
It cooled to 92, lol. Checked BCM connections looked good, but have no way to check board out looks good no burns or anything like that also flasher is. Also the relay changed that. What you think my friend? Blessings, Bernie
Aug 30, 2018 at 11:40 AM
WHSW2002
MEMBER
Not sure what you meant after stating you have no way to check out your BCM, could you repeat it please? I have been following this adventure to learn from. I was just out on LI in July, visiting family. Was warm then as well.
Aug 30, 2018 at 11:43 PM
CERTIFIED EXPERT
Yep, there is not way for you to actual test the BCM, but you can have the unit scanned to see what the health is. This will need to be done by a shop or the dealer. If the BCM is bad it will need to be programmed into the car before a new one will work which usually costs about $130.00.
Aug 31, 2018 at 10:12 AM
BERNIE WINE
MEMBER
I will take out and have it scanned. Thanks again Ken. I will keep you posted. Have a blessed weekend.
Aug 31, 2018 at 12:30 PM
BERNIE WINE
MEMBER
Just found a computer rebuilds. G7 Computer Repair, have you heard of them Ken?
Aug 31, 2018 at 3:59 PM
CERTIFIED EXPERT
I think so, are you going to send it in?
Aug 31, 2018 at 7:13 PM
BERNIE WINE
MEMBER
Yes, pulling out today sending out Monday $235.00.
