Issues after replacing the turn signal switch?
2001 GMC SIERRA
300,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
THERESASUE
I replaced blinker switch. Because I had no dim light it fixed the problem. But a few days later I went out to finish putting the dash back together and it would turn over but not start. so, I figured it was the TBC fuse for the security lock out thing again. so, a few days later got fuse put it in. Fob would work, no dash lights, I had binging with key for a little bit. Emergency flasher I could hear but not see. Now nothing.
Jan 27, 2024 at 1:29 PM
It sounds like the battery is discharged. Have you checked? I say that because you may have caused a short at some point and it is draining the battery.
If possible, take a voltmeter or multimeter and see how much voltage is present in the battery. Or try this simple load test on the battery and let me know what you find:
If you have a jumper pack or a means to try jump-starting the engine, give that a try as well. You could also remove the battery and have it load-tested at a parts store. Most do it free of charge.
Let me know what you find.
Jan 27, 2024 at 9:08 PM
