Blend door replacement?
2016 HYUNDAI TUCSON
122,000 MILES • 4WD • AUTOMATIC
JAX2021$
  • 7 POSTS
A/C works but can't change back to heat, looks like blend door actuator not working. took out glove box but don't see how I can take out frame to get to the actuator?
Oct 8, 2022 at 10:01 AM
STEVE W.
  • 15,113 POSTS
Here are the diagnostics and service info on both blend doors. The metal frame normally isn't removed, you have to remove the duct behind it and then you can get to the blend actuator mounting screws. Now if you have the dual controls and neither one will change temperature then it is more likely the control head instead of the actuator. If you have access to a good scan tool it can be used to test the system without needing to tear it all apart.
Oct 8, 2022 at 1:49 PM
JAX2021$
  • 7 POSTS
Thanks, I think I will let a professional fix this! It's above my pay grade, lol.
Oct 8, 2022 at 4:57 PM
JAX2021$
  • 7 POSTS
By the way, do you know how much they may charge for this job?
Oct 8, 2022 at 5:01 PM
STEVE W.
  • 15,113 POSTS
Depends a lot on labor costs. Shouldn't take much over an hour to do and the part lists at $58.00 currently. So, at $125.00 figure $175.00 to $200.00 if they do diagnostics as well.
Oct 8, 2022 at 6:35 PM
JAX2021$
  • 7 POSTS
Thanks !
Oct 8, 2022 at 9:09 PM
STEVE W.
  • 15,113 POSTS
Good luck, I would call a few places first, it's not a super hard job but some make it into one.
Oct 8, 2022 at 9:49 PM
JAX2021$
  • 7 POSTS
Thanks again! My brother is a retired auto mechanic so we will give it a try. The Hyundai dealer wants $1,500.00 , and I am not paying that for a $50.00 dollar part!
Oct 10, 2022 at 7:10 PM
JAX2021$
  • 7 POSTS
Do you have to remove the center console?
Oct 10, 2022 at 7:12 PM
STEVE W.
  • 15,113 POSTS
Yes, console comes out so you can remove the panel under the center of the dash. This should get you into that spot.
Oct 10, 2022 at 7:43 PM
JAX2021$
  • 7 POSTS
Thank you for your help !
Oct 11, 2022 at 5:24 AM
STEVE W.
  • 15,113 POSTS
You're welcome.
Oct 11, 2022 at 9:03 AM
