My van only has two temperatures, hot or cold. To get it to switch from one temp to the other you usually have to move the temperature control knob back and forth a few times. I believe that the blend door actuator has some stripped gears in it. My real question is where is the actuator hiding under the dash? I've look around on Google but can't find a straight answer whether it on the passenger side or drivers' side of the vehicle. I did a quick look and didn't see it by the blower motor on the passenger side. Please help.
Mar 17, 2025 at 5:38 PM
