I have replaced both actuators up front and have full adjustment ability. My rear HVAC does not have temperature adjustment just fan speed. I pulled off the rear passenger panel to see the system and there was not a blend door or actuator.
When I run heat up front then I turn on the back system the back vents blow ice cold. Did I install it wrong or is there a blend door that is stuck?
Getting frustrated please help!
Jan 29, 2025 at 7:44 PM
