Having issues with my passenger side A/C blowing cold air and the driver side blowing warm air. Obviously, the blend door actuator, which I replaced about two weeks ago and everything worked correctly afterward (cold air both sides or dual controls). Then today out of nowhere the same issue arises with cold on the passenger and heat on the driver (I have my controls set to push out cold air). I take the blend door actuator on the driver side off completely, then plug it in and push the ignition in without the brake and the motor turns (I believe this would mean this new blend door actuator is not broken). However while doing some investigation I notice that the blend door housing (that the actuator fits into) that has the white gear with one area missing a tooth is actually quite loose. Is this supposed to be loose? Or has something come undone behind and is needing to be popped back into place? Should I try purchasing a new blend door actuator and seeing if that solves the issue? Any help would be appreciated! Also, I am trying to upload a video I have of me moving the part around with a screwdriver so if that is not visible please let me know so I can look further into providing that!
Jul 29, 2025 at 11:06 PM
