Location of the blend door actuator
2004 LINCOLN LS
107,889 MILES • 3.0L • V6 • RWD • AUTOMATIC
DEVIN ANDERSON
Where would the blend door actuator located inside my car?
Nov 14, 2016 at 2:52 PM
HMAC300
  • 48,601 POSTS
Here is a guide to help you see what you are in for when changing the blend door actuator out and diagrams below how how to do it on your car:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Nov 14, 2016 at 3:27 PM
BINGHAMTON
My climate control blows whatever air outside inside without any change, hot out hot in, cold out, cold in, moderate out, moderate in.
Jul 15, 2018 at 11:41 AM (Merged)
JDL
  • 16,098 POSTS
Are you saying the temperature control on HVAC does not work? Some makes and models, the HVAC has a diagnostic feature that can enter diagnostics. I will have to double check for your vehicle.
JDL
  • 16,098 POSTS
You can enter HVAC diagnostics. Press the off and defrost buttons at the same time, then press the auto button within two seconds.
The codes, if any should show up on the HVAC display. Let us know about the codes.
GGMYERSJR
If I am correct, there are more than 1 door. Is there a way to tell which one is faulty
04 LS, V8
May 13, 2019 at 9:20 AM
Yes can you tell me which mode is not working? temperature or vent direction?
May 13, 2019 at 1:41 PM
