Only having cold air coming out of the vents in my e250 ford Econoline, previous owner had tried fixing it but ended up cutting a wire which he patched up with a crimp and spare wire. I've replaced the blend door actuator and had no luck (blend door motor didn't even move) so I decided to take apart the old one and fiddle around. Old blend door actuator still moves as when I put it back in after opening it and plugging it in it moves the motor one direction but then stops and doesn't go the other way (Weirdly enough I first noticed it when I had accidently put the motor upside down and when connecting it up again it would do small rotations back and forth in a rocking motion, I think due to being on opposite negative and positive terminals). I can include photos of what I'm talking about and also the cut wire as I removed the previous owner's work to make sure the wires were put back together properly. Any help would be much appreciated as I would love to have heat now it's nearing winter. Thank you.
Sep 19, 2023 at 9:30 AM
