Blend door actuator not working?
2005 CHEVROLET SILVERADO
165,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
  • 13 POSTS
I installed several new blend door actuators. They all do the same thing when I turn the ignition on. They spin and go to one side but don’t adjust when I turn the manual temperatures from hot to cold. I’m unsure what to do. I’ve read other post with testing voltage, and I’m stuck.
Apr 22, 2023 at 3:11 PM
Do you have automatic or manual climate control? You should have dual climate control which indicates there should be two actuators. Does it happen on both sides of the vehicle?
Do me a favor. Try the relearn procedure listed below in pic 1. If that does nothing, we need to move on to testing.
As far as the issue is concerned, if I had your vehicle, I would start by scanning the can-bus system. This vehicle has several computers/modules that control different functions and determine if there are diagnostic trouble codes stored (other than powertrain), this needs to be done.
CAN stands for controller area network. As mentioned, there are multiple modules. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that shows how it's done.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know what you find
See pic below.
Apr 23, 2023 at 8:31 PM
  • 13 POSTS
Yes so, I do have a manual climate control. The issue is only with the driver's side temperature. The vent actuator is working properly and so is the passenger. The actuator I’m dealing with is underneath the glove compartment.
Apr 23, 2023 at 8:35 PM
If the left side isn't working, it should be further to the left of the glove box. The one for the passenger is on the right and behind the glove box.
Take a look at the attached pic and let me know if that is the one you are working with.
See pic below.
Apr 24, 2023 at 6:12 PM
  • 13 POSTS
Yes so, it’s the one on the left side under the glove box. I’ve already had the wire pulled exposed. I hooked up a new actuator or rotates once and it doesn’t move when I manually adjust the temperature.
Apr 24, 2023 at 6:15 PM
Did you try the manual reset I attached above?
Apr 24, 2023 at 7:07 PM
  • 13 POSTS
I will try hopefully later today. The truck is in the shop for other issues at the moment.
Apr 25, 2023 at 5:33 AM
Sounds good. Let me know how things turn out for you.
Apr 25, 2023 at 6:34 PM
  • 13 POSTS
Good afternoon, I just got the truck back today. After just looking at the module I noticed this wire. Could this be the reason I’m having the issue?
May 8, 2023 at 12:57 PM
Interestingly, the white wire with a black tracer controls the passenger side (right side). See pic below.
However, if that wire is damaged, there are likely others. Check for a dark blue wire. See if there is damage. Also, there will be a light blue wire with a black tracer. That provides the 5v reference. Locate that and see if there is power. Also, there should be a brown wire that provides battery voltage. Check that as well. It comes from the HVAC 1 fuse in the interior fuse box.
See pic below.
May 8, 2023 at 7:14 PM
  • 13 POSTS
So, I’ve checked the voltage from the module to the pin (actuator hookup) and I’m getting power.
May 8, 2023 at 7:23 PM
Are you getting the reference voltage via the light blue wire/light blue wire with a black tracer when changing the temp request?
May 8, 2023 at 8:35 PM
  • 13 POSTS
I’m sorry what is the reference voltage?
May 8, 2023 at 9:04 PM
No problem whatsoever. It should be a 5v reference.
May 8, 2023 at 9:14 PM
  • 13 POSTS
I just checked the voltage changing the temperature to hot I get 4.90. Then cold 4.90 and this was for the light blue wire with black in the middle.
May 9, 2023 at 2:51 PM
That couldn't be closer to perfect. If we have the power where it is needed and the actuator isn't reacting properly, I would say you got a bad actuator, but you have replaced them several times.
Question, when you found the voltage, did the 4.9v show positive voltage at the same wire when you changed temps?
May 9, 2023 at 7:57 PM
  • 13 POSTS
Yes, the voltage was the same when I changed from hot to cold, and vice versa.
May 10, 2023 at 2:52 AM
When the motor needs to turn in the opposite direction, the polarity needs to change direction. In other words, it has to travel in the opposite direction for the motor to turn in the opposite direction.
Also, does the voltage change as you move through the temperature slowly? If it doesn't, chances are the controller has an internal fault.
May 10, 2023 at 7:39 PM
  • 13 POSTS
So, I checked the voltage from hot to cold slowly and the voltage did not change. Does that mean the module is bad?
May 11, 2023 at 3:07 PM
  • 13 POSTS
Also, I know noticed that When I change the fan speed 1-3 work (4 stops) and 5 works. This just started today.
May 11, 2023 at 3:58 PM
That would be my first suspect since there is no change at the actuator. As far as the speeds are concerned, it is controlled by a blower motor resistor. However, if it is the module, that could be another symptom.
May 12, 2023 at 6:23 PM
  • 13 POSTS
Okay, I will go to the pick and pull and get a new module tomorrow.
May 12, 2023 at 6:30 PM
Thanks for the update. Let me know if that resolves the issue.
joe
May 12, 2023 at 7:26 PM
  • 13 POSTS
I’m confused a bit, should I be looking to replace the module that controls the temperature, fan speed or am I replacing where the wires connect on the right-side passenger?
May 13, 2023 at 6:02 AM
The control module is in the center dash and is what you control things with. See the attached pics below.
Let me know if this helps.
May 13, 2023 at 10:13 PM
