I believe you have to remove the knee bolster bracket. Take a look at the pic below. I copied your pic and circled the part I'm referring to. Once that is out of the way, you should be able to access the box.
Additionally, I attached the extremely vague directions below. That bracket is held in by 4 screws. Take a look and let me know if it helps. Once the screws are removed, gently pull it away from the panel.
Do me a favor. Before you go to this trouble, confirm it will allow access. This is what is indicated in the manual. If it doesn't, let me know.
See pics below.
Jul 27, 2022 at 7:58 PM
