The vehicle does not have dual climate control. There is a control knob on the driver's side that controls the air flow to the dash vents and AC start/stop. Individual buttons to control defrost, up and down vent usage, et. At the passenger end of the dash there is a dual knob. One is a variable hot/cold to control the temperature of the air exiting the vents. The other is for Max AC.
My belief is that the bad actuator is the one positioning the blend door controlling the flow of hot air and that it is stuck wide open. Would I be correct? Secondly, how many actuators should be on my model Frontier and what do they do? Also, could it be that the hot/cold control knob is somehow not sending open/close input as it is rotated and there is no bad blend door actuator?
May 24, 2025 at 11:43 AM
