Blend door actuator
2005 CHEVROLET AVALANCHE
165,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JTBBLHEAD
  • 4 POSTS
Is there more than one blend door actuator? My drivers side intermittently blows hot regardless of setting while the passenger blows cold. I see a "how to" on replacing but wanted to make sure which one needs replacing.
May 9, 2017 at 10:16 AM
SATURNTECH9
  • 30,869 POSTS
If you have dual climate control then yes you habe two different blend door actuators.
May 10, 2017 at 5:39 PM
JTBBLHEAD
  • 4 POSTS
Where is the drivers side blend door? The how to only shows the passenger one I think.
May 11, 2017 at 4:25 AM
SATURNTECH9
  • 30,869 POSTS
It's number one in the diagram it's pretty easy to get to there is a cover you remove to access it.
May 11, 2017 at 12:54 PM
JTBBLHEAD
  • 4 POSTS
Thanks a lot
May 11, 2017 at 1:17 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome thank you for using 2carpros and please tell all your friends about us.
May 11, 2017 at 2:25 PM
