Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
GMC
Acadia
Climate Control
Blend Door Actuator
Replace/Remove
Blend door actuator
2011 GMC ACADIA
75,000 MILES
RALPH BAKER
MEMBER
1 POST
FOLLOW
Only blows air from upper dash vents can't change but can switch rear on and off.
Dec 28, 2018 at 7:03 AM
CERTIFIED EXPERT
Good morning,
It sounds like you need a mode door actuator as that controls the movement of the mode door. this is a very common failure.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
It is located behind the glove box on the passenger side.
Dec 28, 2018 at 8:44 AM
