The blend air door is responsible for adjusting the air temperature entering the cab. If you can't change the airflow direction, that likely is indicating the mode door actuator may have failed.
Here is the thing. Most vehicles use an electric actuator to move the HVAC doors. In this vehicle, movement is achieved using an engine vacuum provided via a vacuum hose between the intake manifold on the engine and the HVAC controller in the vehicle.
In most cases, if you can't change the airflow direction, there is a loss of vacuum due to a faulty hose. Also, the defroster is the position it will use if there is a problem.
Take a look at this link and let me know if it helps. Also, check under the dash for damaged vacuum hoses or disconnected ones. With the engine running, you may hear a hissing sound if there is a leak.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Let me know what you find.
See pic below.
Nov 19, 2022 at 10:24 PM
