Where is the driver side blend door actuator located?
2020 RAM 1500
89,000 MILES • 5.7L • 2WD • AUTOMATIC
SSHAFFER92
MEMBER
FOLLOW
Nov 25, 2024 at 9:12 AM
CERTIFIED EXPERT
The driver side blend door actuator is located behind the dash down low on the passenger's side. Here is the location and how to change it out. Check out the images (below). Please let us know what happens.
Nov 25, 2024 at 1:26 PM
SSHAFFER92
MEMBER
I have taken the glove boxes off, but still do not see it.
Image (Click to enlarge)
Nov 26, 2024 at 5:54 AM
CERTIFIED EXPERT
It must be above or to the side of the HVAC plenum, I would use a flashlight and small mirror on a stick to find it. They only give .5 hours to change it so it can be too difficult.
Nov 26, 2024 at 11:01 AM
SSHAFFER92
MEMBER
I just had my heater core replaced and that is when the hot air stopped working. I found this connection missing a plug while looking for the actuator. Any chance you can tell me if it should be plugged into something? It is right above the heater core.
Nov 26, 2024 at 12:13 PM
SSHAFFER92
MEMBER
Is it possible the actuator is behind the radio?
Nov 26, 2024 at 12:53 PM
CERTIFIED EXPERT
Yep, that will cause the issue of the heat not working. It is possible the actuator is behind the radio but can I ask if maybe the tech accidently remove the actuator and did not reinstall it? Maybe that is why we can't find it.
Nov 27, 2024 at 10:55 AM
SSHAFFER92
MEMBER
I think I found it on the bottom Of the box closer to the center. It is just tight squeeze. Is it possible for you to tell me what that other connection is for?
Nov 27, 2024 at 2:08 PM
CERTIFIED EXPERT
Nice work, I can tell you what the wiring does, can you start a new thread also include an image of the connector and the wiring color.
Nov 28, 2024 at 11:36 AM
SSHAFFER92
MEMBER
I was able to replace the actuator, and everything is working properly. I just started a new post about the connector. Here is the link https://www.2carpros.com/questions/connector
Dec 3, 2024 at 6:14 AM
CERTIFIED EXPERT
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Dec 3, 2024 at 10:21 AM
SSHAFFER92
MEMBER
Since I replaced the blend door my ac controls will not switch off of the front vents.there is also nothing coming out of the rear vents. Any suggestions?
Dec 6, 2024 at 5:24 AM
CERTIFIED EXPERT
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
