Where is the blend door actuator located?
2009 TOYOTA VENZA
240,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
TYGROOM
My passenger side I can get to blow hot and cold air. My driver side is only cold air. Where is the location of the door motor I need to replace it?
Dec 11, 2024 at 2:39 PM
STEVE W.
  • 15,113 POSTS
It should be up above the throttle pedal assembly on the side of the HVAC case, secured with 2 screws. You need to remove the trim panel below the dash and then look up to see it. There are 2 screws to remove, and the actuator comes off. Install the new one with it lined up on the timing marks as shown. Installed properly there is no programming needed.
Dec 11, 2024 at 5:54 PM
