Blend door location
2000 MERCURY MOUNTAINEER
135,000 MILES
JAMES EDWARDS 1
How to locate the blend door?
Jan 14, 2018 at 4:18 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
For automatic A/C, the temperature blend door is controlled by an electric actuator (motor). The actuator is located on top of A/C evaporator housing.
For Removal and Installation of the temperature blend door actuator:
1.Remove the passenger air bag module.
2.Remove the defroster opening grill.
3.Detach and position aside the right hand demister hose.
Vehicles with anti-theft/key-less entry:
4.Remove the screws and position aside the anti-theft/keyless entry module.
Fig 1: Removing anti-theft/Key-less module.
All vehicles:
5.Working through the opening near the RH defroster nozzle, remove the screw.
Fig 2: Removing screw near right hand defroster nozzle.
6.Remove the temperature blend door actuator.1.Disconnect the electrical connector.
2.Remove the screws and the temperature blend door actuator.
Fig 3: Removing temperature blend door actuator.
Jan 14, 2018 at 6:00 AM
