Blend door
2010 CADILLAC CTS
180,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
FSALTER
  • 8 POSTS
Cold air on driver side hot air on passenger side with A/C on.
Jun 10, 2019 at 5:43 AM
FSALTER
  • 8 POSTS
There are three different actuators on passenger side. how do I determine which one is not working? do I have to remove entire dash to replace it?
Jun 10, 2019 at 5:46 AM
Good morning,
I attached a picture for you to view of the actuator.
It is number 6 in the drawing.
Jun 10, 2019 at 6:14 AM
FSALTER
  • 8 POSTS
That is the one that I replaced already but I still get hot air from passenger side.
Jun 10, 2019 at 6:17 AM
When you command heat and cool, can you feel the motor move?
If you do, then it is not the actuator.
If it does not, remove the actuator and see if it moves off the case.
Jun 10, 2019 at 6:22 AM
FSALTER
  • 8 POSTS
It moves when I adjust temperature to 90 but stops when when going back down at about 78 degrees.
Jun 10, 2019 at 6:49 AM
In or out of the case?
Jun 10, 2019 at 6:53 AM
FSALTER
  • 8 POSTS
In the case.
Jun 10, 2019 at 6:55 AM
Remove the actuator and see if you can move the arm manually to get cold air.
There may be an obstruction in the case door.
Jun 10, 2019 at 7:02 AM
FSALTER
  • 8 POSTS
Okay, I will try that. but could it also be #7 in picture?
Jun 10, 2019 at 7:28 AM
If you said it moved with a command from heat to cool and back, good chance you have the correct actuator.
Check the others as well for movement.
Jun 10, 2019 at 7:30 AM
FSALTER
  • 8 POSTS
Okay, thanks.
Jun 10, 2019 at 7:31 AM
You are welcome.
always glad to help.
Keep us updated.
Jun 10, 2019 at 7:33 AM
