I rebuilt the ALB modulator after having a problem with the brakes, when trying to bleed the brakes after the rebuilt all wheels bled perfectly only the right rear wheel it had no brake fluid pressure.
when stepping on the brakes for several times and trying to bleed the pedal will not go down at all.
I removed the brake line going to the related wheel from the modulator and also had no pressure at the modulator.
Appreciate your help with this.
May 8, 2017 at 12:00 PM
