Bleeding coolant system
2005 DODGE DURANGO
136,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SOULSTEALER6X6
Where is the plug to bleed the system?
Sep 25, 2018 at 8:15 AM
Good afternoon.
There is no bleed valve for the cooling system. You need to fill it cold, then run it until the thermostat opens and then top it off.
Refilling cooling system
Warning: do not remove cylinder block drain plugs or loosen radiator draincock with system hot and under pressure. Serious burns from coolant can occur.
Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse.
Clean cooling system prior to refilling.
image Open In New Tab Zoom/Print
1. Install cylinder block drain plugs. Coat the threads with Mopar Thread Sealant with Teflon.
2. Close radiator petcock.
3. Fill cooling system with a 50/50 mixture of water and antifreeze.
4. Fill coolant reserve/overflow tank to MAX mark on indicator stick.
5. Start and operate engine until thermostat opens (upper radiator hose warm to touch).
6. If necessary, add a 50/50 water and antifreeze mixture to the coolant reserve/overflow tank. This is done to maintain coolant level between the MAX and MIN marks. The level in the reserve/overflow tank may drop below the MIN mark after three or four warm-up and cool-down cycles.
Sep 25, 2018 at 11:00 AM
