There is a bleeder on the drivers side only on tracker with no ABS. A strange little valve box is between the 2 rear wheel cylinders on the axle. This box/valve thing apparently cuts fluid flow to rear brakes if the rear of the body raises up in hard braking? I suspect that multiple lines have to be cracked in the bleeding process and the vehicle has to have the wheels resting on the ground for bleeding. Still researching how to bleed. Mine is a 2001 4dr with no ABS. And 4Wd.
Sep 21, 2021 at 4:37 PM
