Can I bleed the brake lines thru the brake hose at the caliper? The rear bleeders are rusted and frozen in, waiting to be twisted off. Thanks.
Apr 14, 2016 at 9:00 AM
HMAC300
CERTIFIED EXPERT
you can try to but normally not successful. for bleeder screws to loosen remove tire, heat around screw cool with penetrating oil, tap around it with a small hammer. repeat 5-6 times then try to break it loose. use a propane torch it doesn't get hot enough to do any harm.
