I have black smoke coming from my tail pipe when I put the accelerator down and the car is down on power.
Jun 7, 2016 at 10:35 AM
CERTIFIED EXPERT
Hey Allen,
Is this a diesel or gas engine?
Jun 11, 2016 at 1:17 PM
ALLAN RISE
MEMBER
Diesel non turbo
Jun 12, 2016 at 1:40 AM
MHPAUTOS
CERTIFIED EXPERT
Has this just happened or has it been developing over a period of time? black smoke in the diesel is often an over fueling problem, you may have a leaking injector.
Jun 12, 2016 at 3:37 AM
ALLAN RISE
MEMBER
It has just happened I have removed the egr valve it is pretty clogged up so replacing it and see if that cures the problem
Jun 12, 2016 at 4:45 AM
MHPAUTOS
CERTIFIED EXPERT
A blocked or badly restricted EGR can cause excessive smoke as it will upset the air/fuel ratio somewhat, so if it is clogged this is not a bad place to start and anyway it should be cleaned or replaced if defective or blocked regardless.
