Sorry but can u also tell me should I dril a hole and weld a small pipe after the trottle plate to install a vacum hose
Without a vacuum hose, the fuel pressure at idling would be too high and that would result in too rich a mixture.
Sorry I don't have any links for automotive courses but if you search around, you should be abkle to find one. It is best to get an acedemy or school near you place of residence as automotive repairs needs to be hands on and not via the web.
You already have the engine in, do you still want to change ?
For the vacuum hose, there should be available lines that you can tap from. On the manifold you should fine at least one or 2 that is suitable. If not, you can use an adapter and tap it from the PCV hose.
Aug 12, 2015 at 7:02 AM
