lots of black smoke?
2004 HONDA ACCORD
179,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
JEFFREYG
  • 5 POSTS
Bad tick over, very bad acceleration, lots of black smoke, is it possible that there is a crack or hole in the intercooler pipes, have checked the injectors none are leaking, new air filter, weird noise from the front passenger side of the engine. Very soft intercooler pipe when compressed noise changes. Any help would be great. thanks, Jeff
Nov 3, 2023 at 5:31 AM
I have seen the EVAP purge stick open which can suck fuel into the engine, but I need to ask if there are any codes?
Here is the location of the purge valve. Please remove it to see if you can blow through it, if so, the valve is bad and needs to be replaced. Check out the images (below). Please let us know how it goes.
Nov 3, 2023 at 10:37 AM
JEFFREYG
  • 5 POSTS
I have no codes showing been checked on computer code machine.
Nov 3, 2023 at 4:37 PM
Does this engine have a turbo? Also did you check the EVAP purge valve?
Nov 5, 2023 at 11:18 AM
JEFFREYG
  • 5 POSTS
Yes, it has a turbo, have not yet checked the evap purge valve hopefully Monday/Tuesday.
Nov 5, 2023 at 12:49 PM
You could have a turbo seal that has let go and it is filling the engine will oil to burn. I would remove the inlet or outlet tubes and check the endplay of the turbo.
Nov 6, 2023 at 8:17 AM
JEFFREYG
  • 5 POSTS
Thanks, i will give it a try.
Nov 6, 2023 at 8:37 AM
Please let us know what you find.
Nov 7, 2023 at 8:20 AM
JEFFREYG
  • 5 POSTS
Turns out to be the turbo. many thanks for your help.
Jan 8, 2024 at 3:51 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jan 9, 2024 at 9:40 AM
