Hey guys,
I have a new problem. When my gas tank is full, I'm getting a black fuel leak from around the fuel filler neck. I drove about 30 miles to work, burning off about a gallon of fuel, and while it was parked for 2+ hours it didn't leak anymore. I did have this happen once before after replacing the fuel pump a few weeks ago. A hack mechanic put it in wrong, not properly attaching the new fuel pump cylinder into the plastic canister, so it was just sort of hanging there spraying fuel all over. I assumed that was the problem since I didn't see it again after properly attaching the fuel pump.
Note: yesterday I filled up a full 14 gallons, then put in a 10 ounce fuel injector cleaner after filling up. So I guess I may have overfilled it barely by doing this and aggravated the leak. But I didn't do anything like that before the last leak a few weeks ago, and I don't think it was anywhere near as full as it is now.
Anyway, I read that the fuel filler neck rusts out on these cars and needs replacing. Is that likely my issue? What other parts should be replaced in conjunction with the fuel filler neck, since they've got 20 years of wear on them.
I'm attaching a video of the leak. It was really bad this morning before I drove it.
Apr 29, 2020 at 10:14 AM
