If there was a balance issue, you would likely feel a vibration in the steering and not the veering issue.
Tell me, is there anything that seems to prompt this to happen? Also, after driving it for a while, is there excessive heat coming from that wheel? Have you checked for a problem with a worn tie rod or another steering component?
Try this. Safely lift one front wheel off the ground at a time. Place your hands at 3 and 9 o'clock and try to wiggle the wheel back and forth. Do the same at 12 and 6 o'clock. Do you feel any play or is there any noise you notice?
Here is a link that explains how a tie rod is replaced. I'm adding it so you know what to look at if there is play and not for replacing a part.
https://www.2carpros.com/articles/tie-rod-end-replacement
Let me know what you find.
Feb 23, 2023 at 7:24 PM
