serpentine belt and the supercharger belt removal
2004 PONTIAC GRAND PRIX
135,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
Hello, I'm looking to remove the serpentine belt and the supercharger belt on my car listed above supercharger.
Dec 18, 2019 at 1:19 PM
Good evening,
I attached the procedure and pictures for you for the replacement.
Let me know if you have any other questions.
The supercharged 3800 engine utilizes two drive belts. The outer drive belt drives the supercharger. The inner drive belt drives the following components:
Generator
Power steering pump
Water pump
Air conditioning compressor
All driven accessories rigidly mount to the engine. Spring-loaded belt tensioners maintain the drive belt tension. Each drive belt has its own tensioner. A drive belt squeak, occurring when the engine starts or stops, is normal and has no effect on the durability of the drive belt. The drive belt tensioner can control the drive belt tension over a broad range of drive belt lengths, due to stretching. However, there are limits to the tensioner's compensation ability. Poor tension control and/or damage to the tensioner may occur after using the tensioner outside of its operating range. Replace the drive belt when this occurs.
1. Lift or rotate the supercharger drive belt tensioner using a 15 mm box end wrench on the pulley nut.
2. Remove the supercharger drive belt.
3. Lift or rotate the drive belt tensioner using a 15 mm box end wrench on the pulley nut.
4. Remove the drive belt.
Installation Procedure
1. Lift or rotate the drive belt tensioner using a 15 mm box end wrench on the pulley nut.
2. Install the drive belt.
3. Lift or rotate the supercharger drive belt tensioner using a 15 mm box end wrench on the pulley nut.
4. Install the supercharger drive belt.
Dec 18, 2019 at 4:01 PM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the instructions from the vehicle manufacturer for the removal and installation of both drive belts from your vehicle. Please go through this guide and get back to us with how everything turns out for you. I hope this guide helps.
Thanks,
Alex
2CarPros
Dec 18, 2019 at 4:05 PM
ALEXTTT
  • 59 POSTS
Thank you! I'll changing them out Friday and will update with my results!
Dec 18, 2019 at 4:17 PM
You are welcome.
We are always glad to help.
Dec 18, 2019 at 4:30 PM
PHILIP AL-HAJJ
Hi there! I have a follow up question to this thread. When changing these belts is it necessary / recommended to also. Change the coupler? If so, are there any special steps that need to be taken? Thanks!
Oct 17, 2020 at 2:16 AM
Not unless there is any noise coming from the pulleys.
Oct 17, 2020 at 3:05 AM
PHILIP AL-HAJJ
Sweet thanks!
Oct 17, 2020 at 1:48 PM
You are welcome.
Always glad to help.
Oct 18, 2020 at 2:47 AM
PHILIP AL-HAJJ
Hey, what does the Vin 4 mean in the diagrams?
Oct 18, 2020 at 10:49 PM
The engine for the car. It is a 3.8 option. It is the 8th digit in the VIN or vehicle identification number that identifies your engine size.
I attached a chart for you of the VIN breakdown.
Oct 19, 2020 at 1:35 AM
