The inner belt uses a standard tensioner, you put a wrench on the bolt in the middle of part a and you rotate it enough to get the belt on, Be sure you have the correct belt as that engine is very close with belt length. The stretch belt needs the installer tool, I have used a couple tricks on them but it's very easy to damage that belt if you have never installed one before. You might be able to borrow one from a parts store.
Mar 26, 2020 at 3:09 PM
