A/C belt
2000 SUBARU LEGACY
228,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
BLANCA LOPEZ
  • 13 POSTS
My AC belt tension-er digging into plastic timing cover and it has a really bad growling sound.
Feb 8, 2018 at 10:27 AM
After watching the video (and by the way, it was helpful) I feel you have one of two possible problems. First, remove the belt and make sure the tension-er is not loose. If it is tight, the bearing is bad. You will most likely be able to feel play in the pulley when the belt is off.
Here is a video of replacement on a different type of car, but the same basic principals apply:
https://www.youtube.com/watch?v=zUNguWiv714
Feb 8, 2018 at 6:39 PM
BLANCA LOPEZ
  • 13 POSTS
How do I make sure the belt tensions are not loose? Thanks for the response! I also wanted to make sure that the noise I am hearing is because of belt tension-er
Feb 8, 2018 at 11:19 PM
You should have approximately 3/4" up and down play when adjusted.
Feb 10, 2018 at 8:32 PM
