Belt tightening, the battery will not charge?
2007 TOYOTA TUNDRA
1,000,000 MILES • V8 • 4WD • AUTOMATIC
WILLIAMG SHARP
Belt tightening Battery will not charge?
May 13, 2025 at 1:20 PM
Can I ask if the belt tensioner is in good shape? This is what holds tension on the belt to keep it tight. Can you upload an image or a short video of the problem so I can see? Here is a guide to help test the alternator, also please check the fuse numbers in the images below to make sure they are good to go.
and
May 14, 2025 at 12:45 PM
