Belt tension-er rattles at idle and has slight play
1989 BUICK REGAL
56,100 MILES • 2.8L • V6 • 2WD • AUTOMATIC
COOLOLDS85
  • 173 POSTS
I just replaced the belt tension-er and drive belt. Is it normal to do this? Or should be quiet and with not any play being able to move? I checked the belt tension-er to see if it was loose and it was tight even tho it rattles back and forth when engine running. Everyone told said it is normal because the tension-er needs to have some play so the belt and accessories can move smoothly. But does rattling mean the tension-er has an issue?
Oct 21, 2018 at 9:35 PM
The tension-er should not be rattling. You should be able to move it, but it should require a lot of force to do it. Take a look through this link and see if it is helpful.
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
Here is a link that shows how to (in general) replace one:
https://www.2carpros.com/articles/replace-serpentine-belt
With that in mind, either you got a bad tension-er, it is incorrectly installed, the belt routing is incorrect, or they sold you a belt that is slightly too long.
Check for those types of issues and let me know what you find or if you have other questions.
Oct 22, 2018 at 5:45 PM
COOLOLDS85
  • 173 POSTS
It doesn’t rattle to the extent that it is falling off, it is installed the correct way. Just has slight amount of my play. The belt is the right size too. I made sure before I bought the belt. The belt doesn’t squeal, just hear a small rattle sound from the tensioner. But the tensioner moves a little bit when the belt drives the accessories. I thought it was supposed to be like that so it won’t bring tension on the belt when it drives the accessories ect
Oct 23, 2018 at 3:04 PM
Welcome back. It is common to see some movement. However, I thought it was making an excessive rattling sound. That would not be normal.
Oct 23, 2018 at 5:37 PM
COOLOLDS85
  • 173 POSTS
Thank you, Not real loud, just a little at idle. That’s about it.
Oct 23, 2018 at 9:25 PM
You're welcome. Sorry about my misunderstanding on the first post. They all move a little. I thought it was excessive and making a lot of noise. .
Oct 24, 2018 at 5:24 PM
