Hello, I am currently having issues trying to remove a belt tensioner. My initial plan was to remove the belt so that I could replace the compressor and add a new belt as well since the one I have was very old and going bad. I came across the issue of the bolt on the tensioner being completely rounded I suppose from some previous service or so. I was not able to remove it with any tools I had and wasn't able to use a nut splitter either. I tried using a Dremel to cut the nut off but that doesn't seem to work so well. There is limited space so some tools I cannot use. Could there be a certain way to go ahead cutting it, maybe heating the nut or a stronger tool to use?
Mar 28, 2022 at 12:23 PM
