belt making screechingnoise when steering wheel is turned, car smoking
1999 HONDA ACCORD
95,000 MILES • 2.4L • 4 CYL • AWD • AUTOMATIC
KERRYCCU
I made a too tight left turn getting on I-75, and ran over some garden pavers edging the median and heard alot of scraping and bumping under the car. I couldn't stop, but the car seemed ok. 3 days later I was backing out of a parking space and again I ran over some pavers edging a garden bed. drove the car home and it was smoking and the belt was screeching when I turned the wheel. Also I have some oil leaking. What on earth did I do?
May 13, 2015 at 4:34 PM
MHPAUTOS
  • 31,937 POSTS
You may have damaged the front engine pulley or even cracked the sump, get this checked out ASAP and make sure the oil level is safe before driving again.
May 14, 2015 at 3:13 AM
KERRYCCU
Thanks for your prompt reply. If I add top off the oil, can I drive it to my mechanic, about 25 miles away, or should I get towed? Second question approximately in dollars, how much is this going to cost? Or is this a big job?
May 14, 2015 at 3:45 AM
MHPAUTOS
  • 31,937 POSTS
I feel that the prudent thing to do is get it towed, with out actually seeing this problem, I would advise to take the safe option, as for cost, just too hard to say, once again sight unseen it could be anything.
May 14, 2015 at 4:35 AM
KERRYCCU
Thanks, I will get a tow. Kerry
May 14, 2015 at 5:56 AM
MHPAUTOS
  • 31,937 POSTS
Good move! good luck with this I hope that this is not a major problem for you.
May 14, 2015 at 6:35 AM
