Beeping when turning off engine?
1992 HONDA ACCORD
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARCIA ROVINS
Twice, in the past few weeks, when I shut off my engine and take the key out the car beeps like it would had I left the headlights on. If I take it out of park and put it back again, it's fine. It's really hot here in S. Nevada and I believe both times it happened I had driven home after my car was out in the sun for a few hours.
Aug 10, 2025 at 4:10 PM
To me it sounds like the ignition switch is worn out, this will cause the beeping like you left the key in the switch. If it only does it in the hot weather I would not worry about it. The only thing I would look at is to make sure the car is not overheating which may cause the chime as well.
Aug 11, 2025 at 10:57 AM
MARCIA ROVINS
Thanks so much for the reply.
Aug 11, 2025 at 12:10 PM
You are welcome, let me know if you need anything else, we are here to help.
Aug 11, 2025 at 1:14 PM
