Beep on my dash and cuts out
2004 VOLKSWAGEN JETTA
60,000 MILES • 2.0L • 4 CYL • AUTOMATIC
GIGI5592
I was driving and the car started to beep on the dash. This morning I was driving and when I stopped the car it cut out. Twice I turned on my car and the battery light was on. When I shut the car down and then restarted it the light went off.
Sep 28, 2017 at 11:44 AM
MHPAUTOS
  • 31,937 POSTS
This is a bit hard to say with out actually seeing the problem first hand, but i would start with a code scan to see if any fault codes are set. can you also advise the VIN number as there are three different variants in the two liter model?
Sep 28, 2017 at 5:46 PM
GIGI5592
Yes, I will get the alternator, battery, starter checked this weekend first. if good I will have it scanned.
Sep 28, 2017 at 5:54 PM
MHPAUTOS
  • 31,937 POSTS
okay, good luck.thank you for using 2carpros.
Sep 28, 2017 at 6:00 PM
GIGI5592
Thank you for the help.
Sep 29, 2017 at 12:06 PM
