bearings, abs and traction light
2007 FORD FOCUS
117,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
NOREEN MCDONALD
i have had both my rear bearings change and now one of them have gone out again. also my ABS light is on . do they have a connection why both are out now . why does the bearing go out so much?
Jul 15, 2016 at 2:37 PM
WRENCHTECH
  • 20,761 POSTS
I can tell you what is making the bearing wear out prematurely. That can be related to parts quality or installation errors. ABS sensor usually read off a reluctor on the hub so a bad bearing will cause the air gap at the sensor to change and set a code. You need to have the ABS codes read to find out if that is even the issue.
Jul 15, 2016 at 2:58 PM
