Bearing replacement
2008 CHEVROLET UPLANDER
98,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MILITARYMECH
I just changed both wheel bearings in front and after changing them the computer threw on and light, stability system and traction control. What do i do now?
Apr 20, 2018 at 9:34 AM
Good morning.
Is the ABS light on?
Apr 20, 2018 at 9:48 AM
MILITARYMECH
Yes.
Apr 20, 2018 at 9:58 AM
Okay, when the ABS light is on it will disable the trac control system. we need the code to narrow down the area of failure.
check the sensors and make sure they are plugged in and no damage to the connectors and wiring.
you can go to a parts store and have them read the ABS code for you. once we have that code we can continue
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Apr 20, 2018 at 10:05 AM
MILITARYMECH
Okay.
Apr 20, 2018 at 10:09 AM
keep us updated so we can continue to help.
Apr 20, 2018 at 10:10 AM
