BCM pin out needed?
2004 GMC YUKON
205,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
MCANADA1779
  • 4 POSTS
I did a complete interior swap on my 2004 Silverado base model with a 2004 Denali interior. I need to use my base model BCM, but when I do my gauge cluster lights will not turn off. When I use the Yukon BCM I get a lift gate error because the wiring for it has been removed. I would like to get a pin out for the BCM for the Yukon so I can compare it to the pin out for the Silverado at the porting that controls the IP lighting.
Jul 26, 2023 at 1:40 PM
Sure, here is the BCM pinout and the BCM wiring diagrams. I have also included a guide to help you test the connections.
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jul 27, 2023 at 5:22 PM
MCANADA1779
  • 4 POSTS
Is the pin out the same for the 2004 Silverado single cab base model BCM?
Jul 28, 2023 at 9:10 AM
Maybe, if you would like that information as well please start a new question.
Jul 29, 2023 at 12:29 PM
